Re: H Tire Mounting
Posted by old on April 29, 2008 at 11:09:30 from (4.244.90.128):
In Reply to: H Tire Mounting posted by Gauger on April 29, 2008 at 10:47:48:
Yes that seems high unless there filled with fluid and then thats about right. And yes with the right set of tools and the knowledge of how to dismount and mount tires you can do it your self but its not an easy job. BTDT and do my own tires but I also did that for a living for a little while. Some of the older tractor manuals will explain how to do it and if you need to have that info drop me an e-mail and I can scan that page in one of my manuals and send it to you
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
