Re: cracked head??
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Peter on March 09, 2000 at 16:18:08 from (216.78.11.187):
In Reply to: cracked head?? posted by Sly on March 19, 1999 at 15:53:46:
There is a kit to check for combustion by products in the radiator avialible at NAPA stores and elswhere. this will tell you if the antifreeze is coming from the head/head gasket or sleeve. If it checks bad get a spark plug adaptor and rotate each piston to TDC. Fill the cyls w/air one at a time, on the damaged cyls water will blow out the radiator.
If there is no combustion by products, drop the pan and pressurize the rad. Water will likely leak from the sleeve o-ring or elsewhere.
I just opened Advanced Cast Weld Inc. I have 22 years experience and I am a ASE Master Engine Machinest. (I repair broken castings!)
Peter Sattler
337-457-0908
Post A Followup
: Re: Re: cracked head??
