Re: 686 reliability/quality
Posted by karl f on April 29, 2008 at 14:00:15 from (172.168.51.83):
In Reply to: 686 reliability/quality posted by Mark W. on April 29, 2008 at 11:22:55:
thought of a downside: depending on your intended use, you may not like the speed availability.
it is a 5 speed trans, 10 with TA. Their is only 1 reverse, 2 with TA
great for alot of things, but for pto work at rated engine speed, 1 TA is too fast sometimes--our 400 is the same way. there should be about 2 more gears below 1TA, plus the TA. and at least one between 4 and 5 plus the TA. On reverse, one a little slower, and one equal to about 4th gear.
if you have the direction reverser, then you have 5 reverse speeds a little faster than the corresponding forward gears, but lose the TA and still lack lower speeds than 1mph at full engine rpm.
if you need more speed options, then something like a 684, 784, 685, 885, etc would be more suitable. 8 gears from a crawl all the way to transport speed. plus some have a TA (not very well received on those models with tractor guys).
karl f
