Re: dead battery
Posted by Jim Broughton on April 29, 2008 at 14:09:02 from (4.243.1.235):
In Reply to: dead battery posted by EH in KS on April 29, 2008 at 13:57:56:
Easiest way to "fix" is to put a battery switch on your Positive ground cable at the battery.... or you could disconnect that cable when not in use..otherwise it's check out time for shorts with you meter !
Good luck !
Jim
