Posted by onefarmer on April 29, 2008 at 14:18:36 from (216.93.88.138):
In Reply to: dead battery posted by EH in KS on April 29, 2008 at 13:57:56:
There are only so many places for a voltage leak on a H. Here is what I would do. Take a Batt cable off and connect one lead of a volt meter to the batt post and the other to the cable. Check the meter for a voltage reading. If no reading there is no voltage leak in the system. If there is a reading, start removing things from the electrical system. Start with the ign switch, then lights, regulator.... Soon as you remove something and the volt meter drops you found your leak.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
