Re: What goes in the hole above the on/off switch on a SA?
Posted by Hugh Mackay on April 29, 2008 at 14:33:41 from (209.226.106.32):
In Reply to: What goes in the hole above the on/off switch on a SA? posted by SteveNH on April 29, 2008 at 06:43:30:
Steve: The fuse holders are still available at CaseIH. I bought one last fall, and for the price you can"t make two other stops 5 miles out of the way.
