MAGMAN said: (quoted from post at 17:23:02 04/28/08)
What is the correct way to adjust a pressure plate? on the tractor or tight on the fly wheel? on a flat surface?or what?
JON
The correct way to adjust the clutch is on a flat surface. They will be two adjustment measurements. One is the distance between the friction surface of the cast plate and the underside of the clutch cover at the mounting bolt holes. The other measurement is the distance between the friction surface of the cast plate and the levers at the point where the release bearing make contact. These dimensions are installed heights so you need some way to hold either the cover or the levers at the correct dimension while you make the adjustment to get the other dimension correct. It is one of the last steps the rebuilders do when remanufacturing a pressure plate assembly. These adjustments are made to very close specs, usually within a couple thousands of an inch. All the rebuilders I know of do not want any field adjustments made to their rebuilt units. If there is a problem they will exchange it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
