Re: H Tire Mounting
Posted by trucker40 on April 29, 2008 at 19:15:15 from (69.155.104.176):
In Reply to: H Tire Mounting posted by Gauger on April 29, 2008 at 10:47:48:
To break tires down all you need is a tire hammer or a wedge or both.Its not easy,but its not too bad if you know how to use a tire hammer.The sad thing is tire tools and hammers arent all that cheap.If it has fluid in it you have to pump it out someway into an empty 55 gallon barrel works good.It would be a good idea to watch somebody use a tire tool first before you try it yourself.Also its easy to pinch a tube,or tear the bead on a high dollar tractor tire,if you dont know how to change tires.Maybe 120 isnt too bad a price.2 tire tools and a tire hammer would probly cost 100 dollars,maybe a little less,and if you dont know how to use them,may have to spend 120 more to get them changed,unless you can borrow the tools and know how to use them.
