Re: Re: Priming Hydraulic pump
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on March 09, 2000 at 17:44:03 from (206.28.174.149):
In Reply to: Re: Priming Hydraulic pump posted by Fudd@Work on March 08, 2000 at 19:22:46:
Another way to prime the pump without the engine running is to loosen the bolts which hold the lines to the pump ang blow in the filler hole with the air hose till you gat oil comming from the loosened line then tighten the line back up. should work.
Post A Followup
: Re: Re: Re: Priming Hydraulic pump
