Re: Tips on Removing Farmall MD engine
Posted by n9lhm on April 30, 2008 at 08:35:28 from (69.48.41.2):
In Reply to: Re: Tips on Removing Farmall MD engine posted by Nick@KY on April 30, 2008 at 07:13:04:
No, the side rails have to come off. They are bolted to the flywheel housing and those same bolts hold the engine rear plate to the flywheel housing too, so they have to come out. Since they are the only support for the bolster, it has to come off too. Easiest way is to leave the bolster attached to the side rails and lift both up with the cherry picker. After you put a little tension on them then you can remove the four bolts that hold the side rails to the flywheel housing.
