No one mentioned it, but there is a helper spring system that is part of the one point fast hitch for the 140. If you have the rockshaft arm on the left that is made for the helper spring you could likely add the helper spring system. YOu have to have the rockshaft with the extra bracket to attach the helper spring. The spring is set up so it compresses when the lift goes down (Of course reducing down pressure on the lift). When you lift, then the stored energy adds to the lifting capacity. I don't know how much this system adds to the lift capacity, but I would estimate maybe 200 lbs or so. My owners manual lists several example equipment items with weights for the fast hitch. The heaviest item is 610 lbs. I used to have a work saver 3 pt with no helper spring. The limit was around 500 lbs for that. I now have a fast hitch with the helper spring. It will lift more, but I don't know how much.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
