Farmall Tractors Discussion Board
Re: F-14 power lift parts-info
Posted by F14 on December 18, 1998 at 03:08:00:
In Reply to: F-14 power lift parts-info posted by Dale on December 17, 1998 at 18:31:27:
This type of mechanical linkage was fairly common, and, as I understand it, usually included as part of a particular implement. To put it another way, each implement came with it's own "Rube Goldberg" to lift it, powered from a gear on one axle or the other.
Finding parts should be quite a challenge. Best bet would be a boneyard that has a good selection of older Farmalls. The ATIS Farmall discussion group had a couple of guys (Tw and Goodwrench) who found a treasure trove somewhere in Texas...Might be worth your time to hang out there for a bit.
Post a Followup
: Re: Re: F-14 power lift parts-info
