Re: 706 fasthitch problem
Posted by cb-btf on May 01, 2008 at 17:18:47 from (76.100.196.157):
In Reply to: Re: 706 fasthitch problem posted by the tractor vet on April 30, 2008 at 20:01:19:
Turns out that the draft sensor adjusting bolt, spring and two washers are missing. Some where in the bottom of the hydraulic fluid or already ground to bits. Looks like everything else is as it should be. SO, I'm hoping that when I replace the bolt, spring and washers, everything will work as it should.
