Likely you have failed brake piston seals in the left brake, or a load of air in that side if you are lucky. The right brake works OK by itself, but pushing both pedals opens the equalizing valve (between the master cylinders) and all the oil from both the left and right side takes the path of least resistance. Meaning it is trying to compress the air, or simply is bypassing a piston seal and flowing back to the rear frame. Try bleeding the left brake following the proper procedure. If that doesn't cure it, the left rear axle will have to come off to swap out the piston seals.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
