Re: 684 international diesel - brakes
Posted by JimB2 on May 01, 2008 at 17:28:14 from (99.241.179.24):
In Reply to: 684 international diesel - brakes posted by poorfarmall on May 01, 2008 at 16:25:13:
Hi, you will have to bleed the air out of the left brake. Check the brake hydraulic lines for leaks they run from under battery box on top of transmission to near rear axles. Also make sure your hydraulic fluid level is good and hydraulic filter is clean. Could be a leaky brake piston seal but bleeding will provide a temporary fix.
The bleed screw is on side of differential case above each axle. Search archives and you will find the method to bleed the brakes.
Hope this helps
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
