Re: Trying to get a 330U running
Posted by Bringselpup on May 01, 2008 at 20:20:17 from (216.227.12.220):
In Reply to: Trying to get a 330U running posted by glennster on April 30, 2008 at 18:00:18:
Janicholson said: (quoted from post at 22:03:20 05/01/08) Are you going to share? success is great. JimN
Oh I wouldn't keep this one a secret for anything. It's a classic never assume troubleshooting lesson if there ever was one.
After reinstalling the distributor and again seeing the spark when I let go of the key I knew I was being told something but what it was I could not be sure. I spent a fair amount of time verifying the wiring without coming up with anything new. I hit the net and searched on my symptom and came up with some auto boards with posts that were the same thing. Spark when they stopped cranking. There were some plausible suggestions regarding the starter solenoid and the fact that the act of starting was drawing down the voltage to a degree that the coil could not muster up enough oomph to fire a spark.
That made me realize I had pretty much cleaned every terminal but the ones on the ignition switch. OK so maybe I have a bad connection there and I go out and pull the switch to clean all those terminals.
And that's when I see it plain as day. Never assume that the last person who owned your tractor knew what they were doing when they messed around with it.
The hot wire to the coil from the ignition switch was wired to the accessory terminal of the switch. So when I turned the key on it would indeed send the 6V to the coil. But when I checked the switch with the multimeter turning the key all the way over to run the starter causes the switch to cut off the 6V to the acc terminal while cranking. No 6V to the coil while trying to start means I don't have any spark.
All I had to do was move the wire from the ACC terminal to the IGN terminal on the ignition switch and my spark plug clamped to ground fires every time the rotor comes around. :D
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
