Hyd oil in Distributor
Posted by RBTXS on May 02, 2008 at 19:00:09 from (64.12.116.73):
My SMTA live hydraulic pump is leaking fluid through the seal between the pump and the distributor. In the parts manual, there is a package #356 889 R91 which includes a gasket,rings, seal,washers,etc. Has anyone ever had this leak problem, and, if so, were you able to stop the leak by replacing this seal and seal ring? I don't want to replace the hydro pump. TOO much $$$$$$$$$$.
