Re: H farmall belly pump
Posted by glennster on May 03, 2008 at 14:12:07 from (68.60.242.156):
In Reply to: H farmall belly pump posted by Booth2563 on May 03, 2008 at 12:34:48:
i run hy-tran in the belly pumps, that way if you are sharing implements between tractors, the fluid is all the same. jd runs hy-guard, dont know if it would hurt to cross over, but to be on the safe side,i wouldnt mix em, especially if a tractor has wet brakes or clutch.
