Red Mist said: (quoted from post at 05:46:40 05/03/08) Thanks to all for the suggestions. I'm going to repeat the continuity checks on the gen and field wires to the generator posts; but this time I'm going to check them with the wires disconnected from the VR to make sure I'm getting no feed through the VR. I am now wondering if the field and arm wires are crossed with each other at the generator? That would explain the full "discharge" when I jump the VR from the batt to the gen posts. mike
Well, I repeated the continuity checks from the VR to the generator - but this time with the ends of both leads disconnected. Thus, I got a true reading. (Last time I did not disconnect the leads.) Sure enough, the leads were crossed at the generator. I reversed them to correct the problem, polarized the generator and started it up to 3/4 throttle. Ammeter went positive and measured voltage taken at the battery posts showed 7.40V within just a few minutes. Sweet. This is the first job I've tackled on this beast that has not cost me an arm and a leg. Maybe we'll bond with each other afterall......
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
