New pilot bearing, or accurate measurement of the existing bearing to assure it is OK. New plate, new TO bearing. Resurface flywheel friction surface, and take the same amount off of the rim where the clutch PP mounts to the FW. this keeps the geometry correct. Take out three of the PP mounting bolts equaly around (120 degrees apart)use the three to screw into the rear of the PP where there are three holes of correct thread. These bolts release the PP clamping force from the FW. this allows the pp to be released while putting the engine in. after assembly the bolts are re installed in the FW, after putting in the shaft. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
