Re: F-20 oilpan
Posted by F-Dean on May 03, 2008 at 16:42:58 from (67.72.98.88):
In Reply to: F-20 oilpan posted by Mark Poss on May 02, 2008 at 18:40:45:
I assume the threads in the block are stripped. I would rethread it to 7/16 or depending where it is, use a longer 3/8 bolt with a nut and lock washer. (If possible, put the nut and washer on the outside) You may be able to hold it, if nessary, to tighten it through the side covers.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
