Re: H Trans. Seal
Posted by Wayne in MN on May 03, 2008 at 17:27:31 from (68.119.27.241):
In Reply to: H Trans. Seal posted by Richard O'Mara on May 03, 2008 at 16:02:55:
That is the Lift-All pump drive seal you are referring to. After removing the pump drive shaft, lock the brakes, put the transmission in reverse, and unscrew the coupler nut (turn lefty-loosey) before removing the 3 cap screws. Some oil will leak out through the bearing. You should replace the gasket at the same time. Be sure to get the mating surfaces clean.
When installing the drive coupler, it will self-tighten when using the Lift-All.
