Re: H with no power
Posted by the tractor vet on May 04, 2008 at 13:30:06 from (99.167.214.147):
In Reply to: Re: H with no power posted by Allan In NE on May 04, 2008 at 10:15:02:
Allen back may years ago one of the neighbors farmed 160 acres of plow ground with a plan jane H with a set of two 16's and got along just fine with it over here in the hills So yes and H was meant to pull two bottom plows and should do it in second gear at 8-10 inches deep . So if this H is having problem pulling two bottoms then it needs looked at . Maybe a carb issue or timing issue or it maybe plum slap wore out . My old S/H is plum wore out with only 90 lbs of compression and it will haul three 14's in second on flat ground but a groundhog mound will bring her to her knees .
