Posted by CNKS on May 04, 2008 at 17:01:09 from (216.144.104.128):
In Reply to: 52 Farmall posted by Farmer(Ga) on May 04, 2008 at 16:51:39:
The new coil could be bad, or it might be the condensor. Check for spark immediately after it dies. If it is a good spark that eliminates the electrical problem. New parts can be bad. I put new points and condensor in my M one time, would not fire. Put the old ones back in, it has run ever since. It may be a fuel flow problem. Remove the fuel line from the carb, you should get a pencil size flow. If not check the outlet in the tank and the sediment bowl. If the flow is adequate there is a screen inside the carb fitting the line screws into, check that also.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
