Re: 52 Farmall
Posted by Don L C on May 04, 2008 at 18:31:27 from (24.166.244.229):
In Reply to: 52 Farmall posted by Farmer(Ga) on May 04, 2008 at 16:51:39:
Farmer ---
Check the gas line and screens all the way to the carb.......there is a screen at the carb.....sounds like the gas is not flowing fast enough...could be rust flakes in the tank covering the hole.....
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
