Re: water getting into my exhaust
Posted by Bob Kerr on May 05, 2008 at 07:10:41 from (64.12.116.73):
In Reply to: water getting into my exhaust posted by Charlie M on May 04, 2008 at 14:16:46:
Not sure if replacement manifolds have it or not but check to see if there is a small hole at the lower part of the cast heat shield that wraps around the intake part. The originals have it and it is so water can escape. They tend to get plugged with rust and crud. If the new manifold doesn"t have it check down inside to make sure if you drill a hole you won"t dril into the intake part. Look at your old intake and you will see the 1/8th " hole I am talking about. Also the post about getting it good and hot and really tightening it down is good. A lot of them ran with loose pipes and wore the threads out so they won"t tighten. My M is like that and the pipe flops around since the threads are about gone. A lot of guys welded them up, but I personally don"t like that idea much. New threads and a new pipe is what I am going to do to mine.
