Re: Need help making cub mower deck level
Posted by Janicholson on May 05, 2008 at 07:19:32 from (199.17.6.122):
In Reply to: Need help making cub mower deck level posted by Paul Shuler on May 05, 2008 at 06:18:20:
First measure the tire pressure to assure it is the same!
On flat concrete, measure the tip of blade to concrete (with blade rotated to be under the mount on each side, left/right)to get an accurate difference.
The front of the deck must be 3/8 inch lower than the back of the deck to prevent continuous recutting of the grass.
When the difference in height is determined, I would lengthen the short side that amount (maybe adding a bolt on tab, or rat tail file on the hole. Good luck, tell us how it turns out. JimN
