Posted by Wayne from MN on May 05, 2008 at 09:04:04 from (66.228.243.49):
In Reply to: 1940 H problems posted by Cpieper on May 05, 2008 at 06:55:11:
1. Open the high speed FUEL mixture screw so you can run at max RPM's, let the engine warm up, & re-adjust the high speed screw for max speed & smoothness. Add 1/2-3/4 turn out for extra power. 2. Idle the engine & adjust the idle AIR screw for smoothest running & turn the screw IN 1/4 turn extra for a bit of richness to reduce acceleration stumble & the need for choke. 3. Re-set the idle speed to 500 RPM or so. 4. Now repeat the entire process to verify all screw settings. Service manual & carb kit instruction settings will just get you "in the ballpark" so you can make the final adjustments. If any screw adjustments cannot be performed, the carb needs cleaning.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
