Re: IH 624 ignition problem
Posted by corman on May 05, 2008 at 10:01:08 from (192.135.77.104):
In Reply to: IH 624 ignition problem posted by Janicholson on May 05, 2008 at 07:40:57:
Janicholson said: (quoted from post at 07:40:57 05/05/08) If it still cranks, it should start (unless that model has a fuel shut off solenoid). In which case the wiring will need to be traced and checked with a meter to assess the burnt out component. Letting smoke out of electrical components is usually permanent on the functionality of that part. JimN
Thanks for the reposnse Jim.
Maybe I wasn't clear in my post, but ever since the 'pop' and smoke, the tractor's been completely dead. It won't even crank over. nothing happens at all (no lights after turnign the key to the appropriate place, no turning over when the starting knob is pulled out, etc.).
I've bought a multi-meter and was going to chech for voltage in the wiring to try and see where (if) I have power.
Corey
