That's one of the 42" decks. It could be an IH, Woods, Danco, Brush Hog, or one of several other brands.
An inch lower on one side???? The problem should be obvious just looking at the tractor from the front if the cut is that lop-sided.
Park it on a level surface, walk out ahead of it, get down on your belly, and sight across the front of the deck. An inch is a HUGE tilt, so you should be able to see it.
Mine was out of level just enough that you weren't quite sure if it was cutting even or not, but you could almost see those annoying streaks in the grass. Just the slight amount of wiggle in the mounts was enough to level the deck out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
