Re: MCV valve
Posted by Kevin Meier on May 05, 2008 at 15:42:35 from (64.71.85.247):
In Reply to: MCV valve posted by nates90 on May 05, 2008 at 09:02:00:
When I pull off an mcv I replace all o rings and springs that way there are no questions about what is good and what isn"t. As far as the pump you need a flow rater to check how many gallons per minute you are pumping. I have the parts and the flow rater to check your pump. Where are you located?
