I overhauled this engine and replaced/repaired everything that was out of spec.
The rings and sleeves are the same old factory ones and I did check them for wear and proper clearances. I put a new set of chrome rings in it and spaced them properly.
Now only thing I can think of is that maybe the cylinders were excessivley worn towards the bottom because at TDC on a leakdown test it is solid.
As far as working it.....I've cut my 26 acre pasture twice in heavy grass with a Servis brand pull behind drum cutter, plowed my 1 acre garden with a 16" single once, and pulled a weighted 6' set of disks 5-6 times.
Should I work it more?
Also, since rebuild I've been running 30HD in it. Should I switch to a lighter weight to get a little more friction going?
Like I said, she has LOTS of power and is quite snappy at the throttle just like a new machine. I'm getting clean, clear exhaust and the plugs arent fouling.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
