Super M Clutch Replacement
Posted by Smith1000 on May 06, 2008 at 03:42:53 from (12.213.112.57):
The tractor is split and I have some oil on the clutch and flywheel. I believe most, if not all of the oil, is running out of the valve cover and down into the clutch area.
I removed the flywheel last night. Behind the fly wheel, there is a hub. Should I replace a seal in this area while working on the clutch replacement? Are these prone to leaking? The backside of the flywheel does not have much oil. Thanks.
