Re: h CAM TIMING
Posted by El Toro on May 06, 2008 at 03:59:41 from (64.12.116.73):
In Reply to: h CAM TIMING posted by daniel gillespie on May 05, 2008 at 17:12:19:
If you want the engine to ever run you need to do as Edpap suggested. Then your valve & ignition timing will be in time with No1 piston. Hal
