Re: Video of a problem that plagues me....
Posted by Rootsy on May 06, 2008 at 05:23:09 from (24.176.33.123):
In Reply to: Video of a problem that plagues me.... posted by Patrick Martin on May 05, 2008 at 20:19:51:
Proper cross hatch in a cylinder, both depth of cut and geometry have a lot to do with ring seal. Chrome faced rings are hard and take some doing to seat, this is where proper bore preparation as far as hone comes into play.
The proper way to measure a bore is with a bore gauge. 90* apart, 3 points down the axis of the bore (top, middle, bottom) for a total of 6 measurements, if you are an overachiever measure 3 points at each height for a total of 9 measurements. It is also important to mic the piston on the skirt to make sure it is not worn. Pistons are not true cylinders but are larger on the skirt.
Proper indexing of compression and oil rings on the piston are of utmost importance.
Oil vapor is almost certainly leakage by the rings.
