Re: h CAM TIMING
Posted by Edpap on May 06, 2008 at 05:25:39 from (74.33.240.66):
In Reply to: Re: h CAM TIMING posted by daniel gillespie on May 06, 2008 at 04:32:21:
Hi Dan,
OK now I feel better that i know what you are tring to do. My machine shop could answer this question better than me. if you had the cam reground then they should of done it to the stock marks. if they are giving you that spec then I would say you need an off set key.
I had my machine shop make one for me that i put in a SM. with a stock cam I was not happy with the way it ran. we never got a good track last year to see what it could do. it dyno not much more HP.
Ed
