Re: h CAM TIMING
Posted by ChadS on May 06, 2008 at 09:15:37 from (4.224.78.8):
In Reply to: h CAM TIMING posted by daniel gillespie on May 05, 2008 at 17:12:19:
Any possibility to get a compression reading? Kinda like a "before and after" to see if this has any effect of cyl pressure. Years back, we offset a key for dad"s 50 H that we pulled, was just a H cam. Never got to try it both ways,,, but one way, it took the low end torque out of it,, smoothed it out more the less,,,, at stock, it was aggressvie almost too much power,, so thats the reason why we chose for less,, but never tried to go the other direction,, yet. Was like a .015-.018 offset key. ChadS
