Gordo - JB Weld will hold up for a long time, but it won't last indefinitely immersed in gas.
I've patched several carb floats, strainer screens etc. with JB. Discovered that after 6 - 8 years of exposure to gas the JB tends to soften and lose its bond.
(Incidentally I found the same thing happens to JB when it's continually immersed in motor oil.)
I'm sure there are gas-resistant epoxies, etc. out there - I just don't know what they are.
Any way you can solder the standpipes in place? (Probably not because the sediment bulb body is likely zinc diecast...). Or can you expand 'em (work 'em a bit over a suitable mandrel, etc to start a bit of a flare at the end) to give 'em a light interference fit into the strainer assembly?
For sealing the sediment bulb threads in the tank bottom, regular old teflon tape works fine and it lasts indefinitely.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
