Re: New Clutch Disc for Super M
Posted by Smith1000 on May 06, 2008 at 16:15:10 from (67.54.185.87):
In Reply to: New Clutch Disc for Super M posted by Smith1000 on May 03, 2008 at 16:04:32:
Thanks. I may not be understanding what I am looking at but, it doesn't have a belly pump on it. It has a clutch view opening, which has an opening that is 9 1/2". The clutch disc is 12" in diameter and won't begin to fit through the opening. The rest is all cast housing and it is encapsulated unless split--from what I can tell, unless I am not seeing or understanding what you mean.
The shaft slides about 1" and that's it. Could it be that it can be done on some of the Super M's, but not all. This one has a TA. Not sure if that makes any difference on it.
