Re: Fuel resistant adhesive
Posted by GordoSD on May 06, 2008 at 16:58:48 from (66.115.200.140):
In Reply to: Re: Fuel resistant adhesive posted by Janicholson on May 06, 2008 at 13:14:10:
Seemed like a brilliant solution. Used a tapered nailset the right size and "swelled the tube. It was TIGHT to get in there with my hand. Got it about 1/2 way in. When I tapped it home with a very small hammer, it just reformed back to it's original size, loose. Will go with the PVC cement. I had another old strainer body, so I drilled that in the press with a 19/64 bit. Too small, so I polished the tube on a motor driven cork abrasive wheel til it was a very very snug fit. BTW what size is a letter F bit?
Thanks for the help guys. I'll let you know in a year how much gook is at the bottom of the tank, that is NOT going through the fuel system.
Wonder if I will end up with 1/2 inch of ice down there next winter?
Also just for info, the gasket and strainer from IH was less than 3 dollars.
Gordo
