Re: Farmall Cub Oil Pressure
Posted by Gale Roberts on May 06, 2008 at 21:03:47 from (64.12.116.73):
In Reply to: Farmall Cub Oil Pressure posted by Dick Diederich on May 06, 2008 at 20:21:20:
There is a little plug with a hole for a hex wrench located on the left side of the engine (facing the Radiator) near the rear of the engine near the clutch housing at about the level of the Valve Cover. You can remove that plug and prime the oil pump through that hole......Gale
