Re: A FARMALL STARTER
Posted by Bob M on May 07, 2008 at 06:39:18 from (151.190.254.108):
In Reply to: A FARMALL STARTER posted by 6GIBSON on May 07, 2008 at 04:32:00:
Sounds like either a weak battery or high resistance in a battery cable or the starter switch. (A healthy starter should literally slam the bendix out on 12 volts.)
Try feeding the starter directly with jumper cables from your car. You'll likely find it'll then crank just fine.
(Note: Your battery charger likely lacks output capacity (amps) to spin the starter up on 12 volts. So that test is pretty much meaningless.)
