Re: Farmall Regular
Posted by James Williams on May 07, 2008 at 18:07:49 from (74.46.216.57):
In Reply to: Farmall Regular posted by Kuzma on May 07, 2008 at 15:33:27:
Timing is critical,Find your proper timing mark.Mag should click at mark.TDC should be when the piston is all the way up and right before the piston starts down,If the timing is late this will caues low compression becaues the piston has started down,If its early the motor will kick back.BE CAREFULL
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
