Re: Farmall Regular
Posted by Tom Fleming on May 07, 2008 at 19:24:31 from (209.195.155.84):
In Reply to: Farmall Regular posted by Kuzma on May 07, 2008 at 15:33:27:
I agree. check both the timing, and the firing order before you go any farther.
Also, how far apart did you have this when you say you rebuilt it? Did you have the cam out? do you have the cam/crank timing correct?
thoughts on things to check.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
