Re: Right size farming implements
Posted by Hugh Mackay on May 08, 2008 at 06:39:22 from (216.208.58.138):
In Reply to: Right size farming implements posted by Eric Kaltenbach on May 08, 2008 at 06:14:12:
Eric: Don't let the yellow paint fool you. IH did use some yellow primer, most of it before the days of 544, however they may still have been using it in 544 days. The serial tag should tell you which you have. Besides an industrial 544 should have a model badge 2544. I gather it must be a Utility model with swept back front axle? Is there any print on the model badge besides 544.
It will pull a 3 bottom plow, 8' to 10' disk, IH loaders would have been 2000, 2001, 2350, possibly 2250. That 2001 is not the best having only one bucket cylinder. 2250 and 2350 are quick mount loaders. There are many other loaders that will fit with a bit of fabrication of mounting hardware, many of them better loaders than IH loaders.
