Re: H spark trouble
Posted by El Toro on May 08, 2008 at 09:50:44 from (64.12.116.73):
In Reply to: H spark trouble posted by Ed Hotaling on May 08, 2008 at 08:03:07:
You can easily check to see if the mag is out of time by bringing No1 piston to TDC on the compression stroke then look to see where the rotor is pointing, Should be at the No1 plug tower on the cap. Even if its out of time you should see fire to the sparkplugs by holding a plug wire 1/4" away the plug and have someone to try and start the engine. Should have a hot spark. Hal
