Re: Which oil to use?
Posted by LP gas only on May 08, 2008 at 10:28:50 from (12.11.211.126):
In Reply to: Which oil to use? posted by Another Bob on May 08, 2008 at 10:10:28:
I always use the IH LOW ASH 30 W. It is a little more money, but, it is better for the valves. Stick a piece of carbon under an exaust valve and it gets more expensive
Gary
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
