Re: Which oil to use?
Posted by charles todd on May 08, 2008 at 13:55:21 from (205.242.95.135):
In Reply to: Which oil to use? posted by 658834 on May 08, 2008 at 10:10:28:
MIKE THOMPSON said: (quoted from post at 14:51:30 05/08/08) I ALWAYS USE THE USED OIL OUT OF MY CARS AND PICKUPS 50 PLUS YEARS WITH NO TROUBLE AT ALL AND NO WEAR OTHER THAN NORMAL AFTER THAT MANY YEARS OF WORKING
WOW! My grand-father put used motor oil in chainsaws for bar oiling. As for putting contaminated, used motor oil in a good, running tractor is just plain CHEAP.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
