Re: Farmall M engine update: won't start again
Posted by El Toro on May 08, 2008 at 16:20:44 from (205.188.116.73):
In Reply to: Farmall M engine update: won't start again posted by 1 Dollar on May 08, 2008 at 15:03:56:
Are you sure its getting gas? Remove the plug in the bottom of the carburetor and check for a good stream of gas flowing out. Hold a clean container
to catch the gas. If there's just a trickle or no stream you have blockage somewhere in the gas line or tank or both. There's a tiny screen behind the inlet fitting on the carburetor and it could blocking gas to the carburetor. Remove the fitting being careful not damage it. Hal
