Re: Is my 404 down on power? Question for the older guys
Posted by CNKS on May 08, 2008 at 18:05:14 from (216.144.104.128):
In Reply to: Is my 404 down on power? Question for the older guys posted by JSharp on May 08, 2008 at 07:44:59:
The 404 is a small, light, tractor. The seeder is only 5 ft wide, but heavy. The results you are getting are normal. Put it in 1st and don't lug the engine. As a general rule do not pull a loaded engine below PTO rpm on the tach for more than a few seconds, assuming you are using full throttle. Otherwise your recent overhaul isn't going to last very long. I wish I had one of those!
